Results 1 to 13 of 13
Thread: Gear position indicator wrong 2005 R1200GS
    M Juskiw Ohio mjuskiw's Avatar
    Aug 2005
    Akron, ohio
    Really curious if this has happenned to anyone else.
    For a few 100 miles last week my 05 GS was showing the wrong gear.
    When in first I would see the green N ect.
    It ran normally acted right just showed one gear off.
    All the normal neutral functions worked in second
    could never get it to show first
    Got it to top gear and the problem went away for a bit then came back when I downshifted.
    Washed the bike and havent seen the same thing since. I didnt see anything stuck in the linkage ect.
    Im not an indicator light dependant type of guy so this was a minor annoyance and it has gone away. When I realized I was moving with the green N on my biggest concern was how many things are linked to this idiot light : but it seems nothing was as it ran fine just showed the wrong gear.
    My GS has personality and quirks, I wouldnt want it any other way. Im just wondering if this is something that I should look into harder this winter ? Or if it happens again what should I look for.
    Thanks in advance
    M Juskiw
    Akron Oh
    Registered User glurkus's Avatar
    May 2005
    In The Middle Of Kettle Moraine, WI
    Judging by the lack of response, it dosn't seem to be a very common problem. That being said, when my RT was new, I would have the problem of 4th and 5th gear indicater not show up at all, just a blank. It seemed to happen when it was cold, like less than 40 F. The dealer said that expect some quirks in the first 1000 miles. So far after 11000 miles in only happened one more time and that was last week on a 32 F day, and it was after a lazy upshift from 4th to 5th.
    The fact that your problem went away after washing your bike makes it seem that it might be an electrical problem, like a loose connection. I would check all your conectors to make sure they are tight.
    "There is no exception to the rule that every rule has an exception."
    James Thurber
    ltljohn LTLJOHN's Avatar
    Jun 2005
    Haycock, PA
    I do not know if the GS is the same as the RT but whenever I ride in the rain my gear indicator is messed up like that until it dries. The gear indicator switch is at the back of the transmission. Someday when I have the swing arm off I will fix it.
    USN Retired
    '02 R1150 RT
    Aug 2005
    Akron, ohio
    Thanks guys Ill check all that over the winter.
    Mjuskiw
    Akron Oh
    Southside 'scooter jock BMWRich58's Avatar
    South suburbs of Chicago
    Well,this subject has been discussed widely just not on this particular site.
    I've even experienced this problem and cure. Most likely caused from pressure washing the bike and even riding in the rain.
    Moisture/water or whatever can get inside the plug back by the trans and mess things up. Either you wait till it dries out or take apart the plug yourself and dry.
    Next fill the plug up with dielectric grease to seal out any contaminants. Has cured mine and several others of this "confused gear selection" issue.
    Hopefully it will work for you.
    Rich
    '07 GS Adventure
    I80 & I57
    Aug 2006
    I have had this problem twice on my 05 R1200GS. First time the dealer fixed it by hooking it up to the computer. 2nd time about a year later, they had to replace the potentiometer.
    Aug 2005
    Akron, ohio
    Well its a GS so it doesnt need washed much But it has been in the rain.
    ill definately chek it dry it out and seal it.
    Thanks for the replies
    Mjuskiw
    Registered User markgoodrich's Avatar
    Feb 2007
    Quote Originally Posted by BMWRich58 View Post
    Rich is on the money. I'll add that you need to get a very positive insert of the plug. I actually used a soft hammer and a wooden dowel to get the plug to seat properly. Don't be TOO aggressive....
    Sep 2006
    Bump
    Had a guy email me yesterday with an indicator issue on his 06 RT. His works fine until it gets warm, then the Neutral position does not display...the others do
    I am thinking it's the tranny switch as well...any recent experiences?
    Told him to pull & clean as mentioned here. It is a daily rider but it hasn't been rainy as of late and I didn't ask about pressure washing as it seems to happen daily when warmed up.
    Steve Henson
    EX-Prez SABMWRA MOA Club#62/ current forum moderator
    Nuckin' Futs! tf1200rt's Avatar
    Apr 2007
    SAT - LAX
    I had the same issue on a trip coming back from California in November. Called Henzilla and he suggested it was the tranny switch. There was no moisture from rain or washing the bike. It actually cleared itself and hasn't happened since.
    2005 R1200RT
    2008 Honda CBR1000RR
    1984 Kawasaki ZX750 E1 Turbo
    BMWMOA, SABMWRA, PCA
    Spring Lake NJ, USA
    Dear M,
    Please read: http://www.bmwmoa.org/forum/showthread.php?t=46055 - I've added that info to the tread title. It will help make this more useful for people who may be seeking this info in the future.
    PLEASE do this yourself when starting a thread in the tech sections.
    Thanks!
    Don Eilenberger, Forum Moderator, MOA Ambassador - http://www.eilenberger.net
    Spring Lk Heights NJ NJ Shore BMW Riders New Sweden BMW Riders
    '07 R1200R (current ride) and some bimmers.. and a Porsche
    Oct 2003
    "Big Bend" TX
    It is a digital switch, using three contacts in various combinations. Usually when it shows the wrong gear moisture is causing a short between two of the wires causing the false digital combination of ons and offs. One bad contact inside the switch can also cause the problem but that seldom cures itself.
    Sep 2006
    I'll pass the info on, he's not a member . Just strange it's only the neutral position afer running some miles.
    Steve Henson
