Results 1 to 8 of 8
Thread: Transmission level
    Apr 2005
    Gilbert, AZ
    Transmission level
    An aftermarket book I've got said to check the trans level with the bike on the side stand as opposed to the center stand. Just wanted to see if anyone could confirm this is the correct procedure. Thanx!
    Registered User 1024JLC's Avatar
    Hockessin, DE
    I tried that once, and then had it over to the dealer later some additional service. They said that they had to drain some fluid out as it was 'way over full". They (the service tech and manager) said to fill it when on the center stand, and on level ground. That is how I have done it ever since.
    Mar 2007
    15 M. E. Tampa
    trans level
    Check it while on the centerstand.
    Best to just put the correct amount in when you change it, then you never have to check it.
    Certified Beemerphile TheRoss's Avatar
    Feb 2007
    Texas
    Quote Originally Posted by flars10 View Post
    +1. Have bike on centerstand and drain the fluids when they are hot.
    I measure the fluid that comes out when I drain the tranny (and final drive) as a way to look for fluid loss. In 100,000 miles they have never been low.
    Christopher Ross, Lubbock, Texas
    2011 R1200GSA - Helga
    1974 R90S - Smokey
    Northern Front Range, CO
    what "aftermarket book" said that? i want to be sure that I don't buy it by mistake.
    Ride Safe, Ride Lots
    Wine country wine taster blazer707's Avatar
    Apr 2008
    Windsor,CALI
    Apr 2005
    Gilbert, AZ
    The book is a Clymer - seems pretty comprehensive but....
    Thank you all for your responses
    Quote Originally Posted by azrick View Post
    hmm, i find that VERY surprising, as my Clymer's clearly states that you put it on the centerstand or auxilliary stand (meaning a lift of some type, not the side-stand) to check the level. Is yours the 700+ page Clymer's, isbn1-59969-040-3? if so, see pg 59.
