Results 16 to 22 of 22
Thread: Starter stuck on
    Nov 2008
    This will do the trick....
    First of all, I really appreciate the tips for getting this fixed. I also ran the battery down (all the way, no less) and suffered the ill-fated stuck starter. I charged the battery, and tried again, but none of the tricks worked. I thought I was going to be resigned to hunting down that darn relay to bang on it or pry it open, when the local BMW mechanic gave me this routine. He said it works EVERY time. He was right, as it worked first try for me.
    1. With negative cable disconnected charge battery to full. If it's an old or bad battery that won't take a full charge, replace it before going to the next step.
    2. After battery is fully charged, with key on, hold starter button down, and then reconnect the neg. battery.
    3. As soon as you connect the battery, the bike should start. After the bike starts, release the starter button.
    4. With the bike running, tap the starter button once or twice QUICKLY.
    5. Turn the bike off, and she's all fixed.
    I hope this helps!
    Urbana, IL
    Quote Originally Posted by vectorprime27 View Post
    I hope this helps!
    That does work sometimes. I have done it by having everything ready, ign on, connecting the ground cable and just tapping the starter button then. Seems to pull on the contacts and free them.
    My other bike is a BMW.
    Marty Miles
    edmonton alberta
    starter woes
    Sometimes my starter on my 87LT gives me cause for worry. It occasionally sounds like it is ready to stall out before it decides to spin the engine. Almost like it has to do a half revolution before it is ready to put out max torque. Anybody have a similar complaint? What could be the cause? And does the fuel pump always whine a little?
    Urbana, IL
    Could be you need to clean the brush/commutator area. Or new brushes.
    Nov 2008
    Locating the relay and giving it a rap was the fix for mine. Even with a just filled tank. Although, I'm not sure why my relay stuck with a year old battery at the end of a hour ride. Battery should have been fully charged. Better check the electrolyte level.
    timmyd
    starter relay
    Charge /replace the battery, with batt disconnected, remove starter relay and relay cover. Use a points file to square the contacts and recheck the gap. It only happens with old or discharged battery.(long drain,low output). Your other's diamond nail file works great 'til they catch you. Maintain your batt.
    Carolina Sue Beemersue's Avatar
    sc
    Quote Originally Posted by aces928 View Post
    I started my 1990 K75RT and the starter would not stop. I shut off the kill switch and ignition. I could not get it to stop until I disconnected the battery. Any ideas?
    Most likely your starter relay welded. Usual cause is a low or failing battery. The only thing to do is disconnect the battery ground. Sometimes a sharp knock with a hammer handle will free it. You are not trying to crush the relay, just a sharp but not powerful blow. Personally, I always carry a spare starter relay in case it won't free. Best defense is scrupulous battery maintenance and always keeping it charged.
    Sue
