Vanzen,
I admire your skills: design, creativity and mechanics!!![]()
Laurie
1974 R90S; 2008 Triumph Tiger
"Luck Favors the Prepared."
Vanzen,
you have guts!
What do you do in real life?
"What is beautiful is simple, and what is simple always works"....Kalashnikov, inventor of the AK-47.
Current Bike: '73 R75/5 "Center yourself in the vertizontal. Ride a motorcycle...namaste' "
That has to be one of the most elegantly designed frames I've ever seen! Torsional rigidity will be the rule of the day! If there are any Motorrad engineers seeing this from the old days I bet they're saying"Why didn't I think of that!"
I personally think you should paint the frame a contrasting color from the rest of the motorcycle to highlight it. If the bike is going to be black, paint the frame red like a Ducati.
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
Member Suzuki America luge-less luge team MOA 121830, IBA 20994
[QUOTE=kreinke;277379]That has to be one of the most elegantly designed frames I've ever seen! Torsional rigidity will be the rule of the day! If there are any Motorrad engineers seeing this from the old days I bet they're saying"Why didn't I think of that!"
Many reasons would complicate the use of such a frame in production. Starting with construction cost, packaging of all the components necessary for legal road use would be another, and finally, the market ÔÇô how many traditional BMW riders would be interested ? (the R1200S was introduced, and the market asked: where's the panniers ? the SO says the back seat isn't comfortable ÔÇô the model is not a big seller... Oddly, I own one).
In the late 1960's when the Type247 frame was introduced, design criteria was quite different. The demands of a 60hp engine, tire & braking technology available, and the status of knowledge regarding chassis design and dynamics formed the result. Also, in all fairness, the engineers chose as a design goal, a 'flexible' frame that would perform equally as well on ALL kinds of ROAD SURFACES, as opposed to one that would work best on the race-track. By the early '80s, BMW was looking to discontinue the Boxer, and, as a consequence, development curtailed. (remember the R1 concept ?)
I'm sure the engineers were aware of 'what could be done', and designed what best suited the 'needs' as defined by production and market demands. (although that may be optimistic ÔÇô since Udo Gietl patently rejected the special race frames provided by the BMW factory in the early '70s after a few outings, and hired Rob North to design one that actually 'worked'...)
The frame designed by Rob North and raced by Butler-Smith in the late '70s was as similar to my design as yesterday's technology allowed, and (at least superficially) quite similar at that.
I'm sure that with todays laser cutting and hydroforming technology this frame would be economical to produce. If it succeeds I hope you have the gumption to blueprint, and sell these frames. Surely there's a machine shop with a laser cutter or waterjet that would take on the task.
I see a real market in the "custom cafe racer" segment.
LOL. I know that market pretty well ! I also know of several concerns in Europe that DO market race frames and 'performance packages' that include frame upgrades or custom frames. (visit my web-site http://www.rockerboxer.com to know what is available).
Consequently, I know the costs involved for a limited production and what the quite focused 'old BMW custom cafe segment' might be willing to spend ...
I love it and will continue to come back....
Keep the rubber side down!!
1986 R 80 RS
1992 R 100 R
BMW MOA Life member; Ironbutt Member; Airhead Member
Yam TZ125 seat-base and a Duc F1 upper fairing arrived UPS from Airtech Streamlining today. these two pieces, and a Laverda 750 SFC style aluminum gas tank hammered out by Evan Wilcox will be the sum total of body-work for the OldCro project.
A quick photo-shop sketch:
Very nice work. I think it will be great.![]()
19 BMWMOA Nationals under my belt, and I have no idea what I am doing.
1 step back, 2 steps forward
One always hopes that a project can proceed quickly & smoothly to it's conclusion ... RIGHT !
There's always a demon lurking somewhere in the shadows to thwart the best of plans and attempts ! No project runs to completion without glitches, eh ? The front shock mount worked perfectly with the donor-Duc-mock-up shock ... Not so with the first Ohlins intended to replace it ÔÇô interference with the perpendicular reservoir. Not so with the second ÔÇô parallel reservoir and adjusters, but still a poor fit ...
so the entire back of the frame comes off ...
new brackets made ...
frame rails re-cut and re-placed ...
and, finally, we are back on track to "make it right" and just about almost to that stage of finish ... where we were 2 weeks ago ...
I thank "the gods of speed" that Randy is a patient man and a consummate professional.
1 step back, and 2 steps forward ÔÇô swing your partner, and here we go.
The Ohlins is now at home with a "new & improved" front mount, the cross-brace above the swing-arm will be re-placed ... and soon ... on to the sub-frame !
thank you for sharing your work in progess. I always appreciate craftmanship.![]()
Is that a reference to Team Incomplete ?
Glitches and dance steps be damned. We have a main frame ...
and a big dog whos name is not known to me ... yet.
Vanzen, at least your project is well protected... but I thought it would be by a boxer...![]()
looks lit a mix of great protection, maybe boxer/pit mix....
I love it!!![]()
1986 R 80 RS
1992 R 100 R
