Results 1 to 5 of 5
Thread: Best ground R 1200GS ?
    M Juskiw Ohio mjuskiw's Avatar
    Aug 2005
    Akron, ohio
    Ill Apologize in advance if this been covered
    Checked the active threads and didnt see anything.
    Where is the best ground on a 2005 R1200GS ?
    I added XM radio to track the Indians (Central champs BTW) and I have a bit of noise in the background.
    Ive checked the circuit ect all looks good.
    I never noticed it before but I have a little noise off the Zumo.
    The XM seems more sensitive may be the conversion to 5V not sure
    Everyone says its usually a ground
    Mjuskiw
    Akron Ohio
    07 R1200GS Rich's Avatar
    Sep 2003
    Killdeer, ND
    Let me go out on a limb here by suggesting maybe the NEG battery post.
    Sep 2006
    The static is caused by a "loop" in a grounded system. Multiple pathways are created and harmonics come in to play, even when using common battery point.And interference from alternator, and possibly the bikes computerized system. The only easy way to get away from it is to get an RF isolator lead. I have to look where I got one from.Autocamm has one, but I think I got one from another vendor. GF's Roady and her INNO had a buzz until I added the isolator in line with radio. I took everything to battery BTW.
    An Electrical Engineer may step in here!!
    Steve Henson
    EX-Prez SABMWRA MOA Club#62/ current forum moderator
    Aug 2005
    Akron, ohio
    The neg post is actually very noisy.
    Ive had a few Cars that were best when grounded to the frame or block
    Some even provide a nice clean ground for audio.
    Thanks for the good info Steve Ill try the RF isolator.
    Im a Mechanical Engineer in over my head on the electrical theory and happy that way. I had a few credits of electrical and your explanation sounds OK to me.
    Mjuskiw
    aKRON oH
    Sep 2006
    found where I got the isolator lead,seems it was 1/2 the price of Autocomms unit...I have on of each on two diff bikes. The Autocomm's is 'prettier" if it matters and is a male and female set-up as opposed to Hoons being two male connectors. I used them for two diff applications.
    their site is small and it is located under the Roady Holder link
    http://www.hoonhardware.com/RoadyHolder/roadyholder.htm
    here is Autocom's stuff
    http://www.autocomamerica.com/search...tegoryid/23675
    Steve Henson
