Page 21 of 52 FirstFirst ... 11192021222331 ... LastLast
Results 301 to 315 of 775
Thread: How do I post a picture?
  1. #301
    Registered User mktunno's Avatar
    St. Petersburg, Fla.
    Testing photo work
  2. #302
    Focused kbasa's Avatar
    Marin By God County, California
    Wow.
    Great photo, Mark.
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
  3. #303
    Registered User RINTY's Avatar
    Nov 2005
    Calgary, Alberta
    post a picture
    Vince:
    Sign that guy up!
    Is that a Kwaaker behind the S?
    Rinty
  4. #304
    K1200RS
    Mar 2007
    Bellefonte, PA
    just trying to see if i can post a pic right
    taken in the green mountains of vermont during the 06 ralley at essex junction
  5. #305
    Gopheride redrider's Avatar
    Feb 2005
    Montreal area
    Test Photo
    Richelieu River Ride
  6. #306
    Registered User bluehole's Avatar
    Oct 2005
    Midlothian, Virginia
    Just trying to practice this so I remember how it is done. This is what my co-workers did to my Suzuki Bandit, the bike I had before the RT, while I was at work one day. Fun bunch, huh.
  7. #307
    Nov 2005
    Test
  8. #308
    Nov 2005
    Calgary, Alberta
    how do I...?
    Spudpuppy:
    Is that checkerboard trim a factory option?
    Rinty
  9. #309
    Nov 2005
    Quote Originally Posted by rinty View Post
    Spudpuppy:
    Rinty
    Rinty,
    No, I used some scraps of silver vinyl, a 1 inch ruler and an exacto knife to create my own graphics, then applied them. Just like to be a little different.
    Spudpuppy
  10. #310
    Nov 2005
    Calgary, Alberta
    post a picture
    It looks good. There is a lot of body work on an RT, and the strip breaks it up nicely, without interfering with the angles of the feature lines.
    Rinty
  11. #311
    They call me Gort scootrp125x's Avatar
    Sep 2004
    Pittsburgh Pa
    pic size is too big
    I have downloaded irfanview and gone through the instructions to change pixel and dpi size but my photo is too large (197kb). How do I reduce the phote size under the 160kb limit to put on the forum?
    04 R1150RT
  12. #312
    Dances With Sheep GREGFEELER's Avatar
    Boise, ID
    Quote Originally Posted by scootrp125x View Post
    Usually, you will get where you need to be for posting photo size by reducing the photo to no more than 600x800 or 800x600 pixels (depending on if it's a portrait or landscape orientation). That makes for a fairly large photo for the forum, but doable. In a .jpg format it should be under 100kb. Even smaller sizes are easier for people to view who have their monitors set to 1024x768 resolution (lots of laptops) or smaller. Try posting some different sizes here.
    Greg Feeler
    BMW MOA President, Ambassador, & cat herder
    1972 R75/5, 1990 K75, 1990 K1, 1992 K75S, 2003 K1200RS
  13. #313
    Sep 2004
    Pittsburgh Pa
    Thanks. I reduced the pixel size even further it worked. The picture was a bit small but it was okay.
    04 R1150RT
  14. #314
    Jun 2007
    Hot Springs, South Dakota
    Picture Test
    Picture Test
    Hey, that photo is beautiful!
  15. #315
    Jun 2007
    Wait, wait, a minute, you are making this too complicated.
    Every scanner has a dotted scan adjustment feature reflected in the "Preview" screen seen on your computer. Use your "mouse" to drag the edges of this dotted image crop tool over your picture. Don't let the scanner just choose to scan "default". You have to help the scanner decide what size of a job it is asked to do.
    So, you have selected correctly, then choose the type of file you want the scanner to save your image in and where,on your comptuer, the image will be found after you save it. Do not scan it to the internet from you scanner.
    As indicated, don't expect the scanner to save the image in a particular size of photo unless you have entered that value in the scanners "preference" file, or setup file.
    When you tell your scanner to save your scan, it will have a drop down menu to choose from and it will also have a drop down menu to choose an application to send the image to, like Adobe Photoshop or this other image enhancing program being promoted in these posts.
    What is improtant is that an image scanned to a file MUST then be opened in an image enhancing program that can manipulate the image so that it is internet ready, ie. match the upload preferences desired to see the image and conserve space on the host drive.
    I hope this posting is helpful?
    P
