Results 1 to 3 of 3
Thread: K75 Electronics power boost
    Dec 2005
    Bloomington IL
    Question K75 Electronics power boost
    I have a 1990 K75c. I am wanting to put a stronger Head Light bulb in, plus fog lamps and Flashing LED tail lights. I already have the bike set up to have the turn signals as a constant running, in addition to a couple LED tail lights to asist the rear bulb. I am worried that my battery wont be able to support the load. Is there an amplifier out there that I can use. Will a stronger battery help or will the wiring not support the increased power flow.
    CRZ KNUK burnszilla's Avatar
    May 2004
    Santa Cruz Mountains, CA
    You will need a relay for the headlight.
    I'm still waiting for gizmomill.com to make a led brakelight for the K75.
    Stephen Burns - 2007 R1200GS
    BMW MOA Lifetime Member
    www.burnsmoto.com
    Focused kbasa's Avatar
    Get a headlight relay from www.easternbeaver.com for the bigger headlight bulb. There's not cutting and the installation really is plug and play. There's a thread running over in oilheads about bigger bulbs.
    Dave Swider
    Marin County, CA
