Starting last season my 85 R80 won't down shift unless I blip the throttle. I'm the original owner and have never experienced this before. Anyone know why? Thanks.
Printable View
[QUOTE=jimbc;864725]Starting last season my 85 R80 won't down shift unless I blip the throttle. I'm the original owner and have never experienced this before. Anyone know why? Thanks.[/QUOTE]
I have a 78 R100/7 and was having the same problem. You need to have your splines lubed. You have to back the transmission out to get to the splines in question. There is probably a link in the forum for the procedure or you can contact your favorite Beemer wrench. Should clear it up.
Thanks for the info, Jim
Here's a spline lube tutorial with pictures:
[URL="http://www.webbikeworld.com/t2/spline/"]http://www.webbikeworld.com/t2/spline/[/URL]
Or here's Snowbum's article. More verbose but quite thorough:
[URL="http://bmwmotorcycletech.info/inputsplinesthrowout.htm"]http://bmwmotorcycletech.info/inputsplinesthrowout.htm[/URL]
My RS was shifting rough & hard to find neutral, etc. A spline lube made a world of difference. Be sure you clutch is adjusted properly, too:
[URL="http://bmwmotorcycletech.info/clutch.htm"]http://bmwmotorcycletech.info/clutch.htm[/URL] near the bottom.
Thanks for that Mark
Here are some very good videos on how to do a spline lube.
[url]http://www.youtube.com/watch?v=uVKPGcf0xag[/url]
[url]http://www.youtube.com/watch?v=p8dJzD42eYI[/url]
[url]http://www.youtube.com/watch?v=p0Kw38blwfg[/url]
[url]http://www.youtube.com/watch?v=qXXnNQf2F_k[/url]
There is some colorful language used, but very good detailed information provided.
Regards
Amazing what can be found on the net. Thx
[QUOTE=jimbc;865993]Amazing what can be found on the net. Thx[/QUOTE]
...and here's some more "amazing" things that be be found on the net...
[url]http://www.bmwmoa.org/forum/showthread.php?47142-Resources-and-Links[/url]
... nice seque Kurt [img]http://boards.core77.com/images/smilies/icon_wink.gif[/img]
