'99 K1200LT Rear Brake Indexing for Rebuild Reference
I'm in the process of removing my rear drive to send it away for rebuild and am not sure about how to index the rear brake as per the K1200LT service manual. Is there a simple way to do this? What marks on the disc / rear drive should I use, given that during rebuild the rear drive will be handled quite a bit and may remove any marks I make beforehand?
As a reference here is the verbiage from the manual on page 34.9:
"Mark the installed position of the brake disc on the
rear wheel drive, so that vertical runout of the sensor
ring is not altered."
Any help is greatly appreciated.
Bill Edwards
Boerne, TX
1999 K1200LT Rear Brake Indexing for Rebuild Reference
Okay, as you can probably tell it's my first time doing this. So the only orientation to worry about is that the 2 machine screw mounting holes on the ABS ring / disc rotor are realigned using the exact same holes on the rear drive upon reassembly?
Aha. Just reread my reference and see it's talking about "vertical" runout. Now it makes more sense.
Thanks for taking the time to set me straight.
Occam's Razor strikes again!
Bill Edwards
