1 Attachment(s)
73 R75-5 Removing Fork Tube Threaded Ring
Folks,
I'm having problems removing the threaded ring from the bottom of the fork tube. The holes in this ring are not spaced to allow use of the pin wrench included in the tool kit.
[ATTACH]37184[/ATTACH]
I'm making up a pin wrench that will fit this (the diameter of the holes are very close to 1/8 inch). There is not a lot of thickness in the ring. Does it remove easily or is a lot of force required? Any other tips, cautions, etc. on getting this out?
Thanks for the insights.
1 Attachment(s)
Some experience to share...
[QUOTE=brook.reams;851886]Folks,
I'm making up a pin wrench that will fit this (the diameter of the holes are very close to 1/8 inch). There is not a lot of thickness in the ring. Does it remove easily or is a lot of force required? Any other tips, cautions, etc. on getting this out? Thanks for the insights.[/QUOTE]
In the past, I've had good luck using a pair of needle nose pliers with the jaw tips held firmly in the notch on either side of the ID. Every so often I run across 'threaded rings' that are stuck tight in the fork tube. This can be a result of several things like rust, dirt, contaminated fork fluid, etc. Use of increasingly aggressive solvents is appropriate plus heat / cool cycles. I have run across several forks where the rings were 'glued' in place with thread locking compound and they were for all purposes permanently installed. I have resorted to getting a welder to run a bead around the face of the steel rings to shrink them away from the tube walls. That works - it saves the tubes but it destroys the internal parts.
Installed between the lower and upper steel threaded rings is a thick aluminum ring that has a center hole with a specific ID. It is the damper orifice and is critical to fork performance. (There is a [I]sport orifice[/I] designed originally for the R90S which can be installed for more dampening control although I've never put a set in a /5). If you have to, it is possible to push the damper rod up through the fork tube and by giggling gently from side to side [I]pull[/I] the damper rod w/wiper rings past the threads at the top of the tube without damaging the wiper rings. With the damper rod assembly removed it is possible to clean the threaded and aluminum rings and tube inside, the damper rod itself while its out and then reassemble by dropping the damper rod back down through the tube, rings and orifice. There is a slick factory tool (see attachment) used to install the damper rod through the bottom of the fork tube properly so as not to destroy the wiper rings - but, the threaded rings and orifice need to be out of the way (removed) to use it.
