2010 RT Rear Brake Pad Fit Problem
I bought EBC pads for the rear brake, part#FA363HH. After "some" frustration failing to install the pads, with the pistons fully levered back into the caliper, I took some measurements: Two pads plus disc = .950".
Space in caliper = .930" Anyone else have this problem? I suspect I was given the wrong part #, anyone out there have a different part # for rear EBC's / 2010 RT?
[QUOTE=MPMARTY;846863]pushing in the piston is only half the problem. The rear caliper is a slider design. I'd take it off and separate the two halves, clean and lube the pins it slides on and then try it again.[/QUOTE]
The caliper body itself is one piece. Your suggestion won't change the fact that there simply is not room in the caliper for the brake pads I was sold, plus the disc.
Yes it is a slider design but that has nothing to do with the distance between the retracted piston and the left side of the caliper. I talked to EBC today and they believe I have a mis-manufactured pad. They are sending me a replacement. They were very nice to work with.
When EBC sends your replacement pads let us know what you find.
We're waiting... Did you solve your little problem?
[QUOTE=MPMARTY;852487]We're waiting... Did you solve your little problem?[/QUOTE]
Problem solved. Had to pull the caliper all the way to the Left on the slider pins. The pads are an extremely close fit, unlike the fronts which have a little wiggle room. The slider was plenty free.
