Easy-pull Clutch Lever
Has anyone had any experience with easy-pull clutch levers? I have arthritis in my hands and my F700GS's clutch pull causes me a bit of bother. I've read good reports of the RSC lever which reputedly reduces pressure by half. Has anyone tried anything?
I ride a 2011 F00ST and had similar problems w my clutch lever. I switched it to Pazzoracing.com. Their lever position is adjustable so it will be closer to the grip and to your hand. In my opinion the best feature is that it doesn't angle away from the grip as it goes out, thus allowing you to use a stronger part of your hand and fingers. Snappy colors and easy to install too.
Also you should consider speed shifting more often. If you have arthritis remember to use gloves and to keep your hands warm!
Cheers.
Thanks for that. I'll try it out.
