Beware of "THE BOLTS"!
Words to the wise: In going after a valve adjustment on my 2003 R1150R I was removing the OEM valve cover protectors/head guards on my bike. These are the black plastic version with 3 attachment points,one on front and back of kug, the other under the jug. The one under is the culprit in my case and on each side! I encountered resistance there & eventually after trying a soak of the threads I proceeded to break of both of these socket head screws. The guard uses the bolt on each side that is in a threaded hole that is open at the back. My guess is that this allows corrosion to be more likely with these two holes. What makes for a difficult removal is the fact that these holes are both too close to the jug to allow a straight shot into the broken bolt for drilling. Not to get into a "broken bolt tutorial" here but I was able to use a 1/8" drill and keeping the drill very close to the underneath side of the jug, drill through the remaining bolt. When possible I avoid using bolt extractors but had a new Craftsman available and I tapped it into what looked like a doable situation. FWIW, the pkg said made in China. It broke before I could even give it much pressure. The other side I have almost out via more conventional chipping away with hardened steel "needles" I have in my tool box from past industrial work. Seems to be a job for a carbide burr next or maybe even a diamond burr using my Foredom tool handpiece. Heat is a hard sell for me in the jug location w/o removing the finish from adjoining parts.
Beware of these two bolts that are encountered in a common maintenance procedure! It's not an easy spot to work nor a kind to your bike operation.
I'm considering using a through bolt in a clearance size hole next rather than a cleanup the threads operation.
I've seen these black guards criticized before, as compared to the more robust tubing style but find they actually do the job well with little weight, never had an issue before but been some miles since valve adjustment too. Hope I created some caution here.
Steel bolts into an exposed aluminum threaded hole begs for anti-seize upon assembly.
Those are screws.
Bolts need nuts on them.
You are wrong. They are correctly called "sockethead cap screws". FWIW, I made a living needing to know what fastener to call for. Yes Paul, you are spot on!They need anti-seize which they got at the last valve adjustment but as they had me all day with carbide burrs(my entire supply of longer ones from my dentist) they need periodic attention. As mentioned the tight spot & the angle make for a difficult removal.
So did I and I'm literate enough to know a socket head capscrew is a version of screw. I almost wrote the former, but thought it too much.
Nutz n' Boltz
This has me confused.
All these years I've been screwing in my wheel bolts and it turns out they are actually studs. :p
The clutch adjuster is a screw with a nut on it. But it's a lock nut so it can't be a bolt, it's just a screw with a bolt like head on it..
And a wing nut is really a screw with a nut on it too then I guess. Who knew ?
I always thought of a screw as a threaded object that could only be so big and then it was a bolt.
And a bolt was more studly than just a lowly screw...
Aww jeez I'm really screwed now. :laugh
[QUOTE=lkchris;846396]Those are screws.
Bolts need nuts on them.[/QUOTE]
I knew that but misspoke. But that raises an interesting question.
I have in my hand a "thing" with a socket head for a metric 6mm Allen wrench and 20mm length of M6x1.25 threads.
It might go into a threaded hole with matching M6x1.25 threads; or
It might go through non-threaded holes on two or more pieces and thread into an M6x1.25 nut.
My F650, K75, and R1150R all have some of these things attached to them.
So, here it is, in my hand. Is this thing a bolt, or is it a screw. Or does it remain just a thing until I decide where it needs to be installed?
I need to go put this thing back in the little drawer in my collection of things now.
Added after I got back from the parts bin: I just found another thing. It goes through the pivot point on a clutch lever and threads into threads on the perch. But it also then takes a nut on the threaded end too. This one happens to have a straight slot on what would be the top end when installed. So is this a bolt because it takes a nut or a screw because it threads into a threaded hole in the perch? Or is it a screwbolt?
At age 31, I got an "A" in technical writing.:doh I accept that you, Ikchris are literate, which as many greasy types such as myself will attest does not have much to do with nuts & bolts stuff.:laugh As they say these days, "My bad" in calling a type of screw , a "bolt",(:bolt) but it seemed to be a catchy title-too catchy so it seems.:doh
Bottom line is beware of "those two fasteners" on an oil head as they might bite you as they did me. The only usual reason to remove them happens not so often. And Paul, beware of the term "things" as it will not float here in the land of techy stuff & snipers!;)
At my age laying on a creeper for several hours doing "screw surgery" (not bolt surgery!) isn't fun. Especially when the SCREW! hole is in my bikes engine.Hope this causes someone to proceed with caution thereabouts.
After we stop discussing the screw versus bolt nomenclature; this was good tip by kantuckid. Another tip on attaching these 1100 valve cover protectors - I swapped out one of the longer screws for one of the shorter ones, so on each side I'm using two of the M6X16, and only one M6X25 screws. I could not get one of the long screws to seat on both sides.
Oddly, I had the same problem with the exact same fastener last month. Tried various solvents and heat with no effect. Very frustrating. Fortunately, before it stripped completely and refused to budge any further, I was able to unscrew (unbolt?) it enough that I could move the valve cover protector enough to do the valve adjustment. I think I may just have a mechanic drill it out but I'll be interested to see if you find another solution. You say you DID put anti-seize on it and still had this issue? That was my plan to avoid this in the future.
[QUOTE=m_stock10506;846664]After we stop discussing the screw versus bolt nomenclature; this was good tip by kantuckid.[/QUOTE]
Agreed. Had the same issue a couple of years ago. Now I remove and re-antiseize the boltscrewfasteners (new word which should solve Mr. Glaves' dilemma :laugh) yearly.
Aw, nuts!
We're screwed!
Gotta bolt...:bolt
How 'bout "threaded fasteners"?
That would cover screws, bolts, and nuts of any description as long as it had threads.
Plus, we could call them "schraub-Verbindungselementen" when in secret club meetings.
Or maybe not.
I always thought a screw had a + or - slot in it and was installed with a screwdriver.
If its a bolt, I need a wrench or socket.
Yes, Cap head screw or Socket head screw.
I have had the same trouble with the same fasteners. I used Anti seez on them a long time ago. No problems since.
David
In a box store trip yesterday I noticed that TSC & Lowes both have extra long twist drill bits which I should have used to drill out my remnant "fastener". That is the only way you get a straight shot in that location. Instead I used what I had at hand. I'm replacing the lower valve guard attaching "fastener" with a longer version(my threads are loose fit from gyrations of removal) & a nylock nut/washer on the back side & using SS too. I habitually use anti-seize on parts not needing essential torque.I also paint it on hubcentric wheel centers on bike and cars.
I hope you picked up on my glowing endorsement of the Craftsman EZ-out I broke off with almost zero effort. I've broken the USA versions in the smaller sizes over the years(the bigger ones never seem to break) but always was when using far more torque than this time around. It was obviously hardened to point of being very brittle & lacking enough strength for the job. I'm now looking at some made in USA from Cinn.,OH carbide burs on ebay to replace my supply.
