2013 R1200RT Oil level indicator
2013 R1200RT Display - Oil level indicator
Second post here so please be gentle. After reading the manual about 50 times, there doesnÔÇÖt seem to be much information about the Oil level indicator when pressing the info button on left grip. So far I have seen where it says ÔÇ£OilÔÇØ with a few dashes next to it or a check mark. I believe the dashes are that it hasnÔÇÖt taken a reading yet and the check mark means everything is OK. What other indications are available? Also, IÔÇÖve noticed that the Oil indicator may not be there at all when cycling through the different info options but havenÔÇÖt figured how or when it shows up.
Thanks in advance for the help!
Chris
RE: 2013 R1200RT Oil level indicator
Oil indicator on the screen only shows up when your stopped. I always check the oil level through the sight glass which is towards the bottom of the engine on the clutch side. Basically below where the fairing stops. BMW recommends the engine be warmed up to operating temperature and then given 5 minutes after shutoff for the oil to drain back down. It needs to be checked on the center stand.
Sent from my Nokia Lumia 920 using Board Express
Thanks for the quick replyÔÇÖs and for the detail. Very helpful! That make a lot of sense from what I have seen. I was hoping for additional indications like ÔÇ£addÔÇØ if itÔÇÖs a little low but it sounds like itÔÇÖs OK or catastrophic failure! ;)
Thanks again for the quick feedback.
Chris
