2011 R1200GS - Drive line sliding motion??
G'day,
I read somewhere that on the newer bikes like mine, there is no sliding motion in the drive line, and that therefore, because there is no sliding motion, there is no need to drop the rear drive periodically to lube the splines where the drive shaft goes into the final drive. Am I correct in that understanding? Certainly, I don't see drive shaft spline lubing mentioned as a maintenance item in the 6th edition BMW repair DVD that I have for my bike. And I've never seen it mentioned on any work orders from the two dealers who have worked on my bike since it was new (the bike has 46,000 km on it and it is still under warranty).
I know these splines were lubed as part of the re-assembly procedure on the earlier models, because the rear drive had to be dropped to drain the rear drive oil. But since my bike doesn't require the final drive to be dropped in order to change the oil in the rear wheel final drive, is it specified\necessary to drop it anyway, just to lube the splines??
A related question...has BMW issued have some Service Bulletin or something that calls for periodic drive shaft spline lubing, that they didn't bother mentioning in their repair DVD? (After a while, I am starting to get nervous that the BMW repair DVD isn't all inclusive, and can't be relied upon by do-it-yourselfers, to be aware of all the maintenance requirements).
Thanks for any insights.
Dave McDougall
2011 R1200GS
can i assume that applies to the r1200r also?
Spline wear. 2006 R1200RT
Sliding is not the only determining factor for spline wear. For example on a truck with a PTO (Power Take Off) mounted on a transmission with a hydraulic pump bolted solid will have spline wear. There is no sliding motion at all but the splines can and do wear out. In this case you will have a male and female spline made of the same hardness material and the two will just work against each other and fret. The splines will have similar loss of material. Lubing definitely will slow or eliminate the loss of material. Once material is lost now there is room for the two objects to have movement and start bouncing if you will against each other with the power pulses of the motor.
Happy Riding
