Heated Grip--left side fail
Hey all, my 98 R1100r left side heated grip has failed. I've got proper voltages at the rocker switch (hi-11.5v/low 9.5v) and at the wires to the element in the grip. Since buying this bike from the PO, I've had to clean/lubricate the switch internally, and only just realized that it was 3-way, as it was physically stuck from corrosion.
I've also tested for continuity between the leads at the grip, which was good.
So if I've got voltage and continuity through the circuit, where is the failure? I guess the one last thing to do is check the connection at the main wiring harness under the tank, correct?
Thanks!
