I have an 03 Gs 1150. The front signal lights fail to work after crash. The rear signals flash but very quickly.Any ideas would be greatly appreciated.
Printable View
broken bulb(s).
the decreased resistance to the circuit is what is causing the fast flash rate.
I've tested the bulbs and they are good. I'm thinking maybe a connection under the tank?
the turn signals get stripped away from their connections?
that would be a next option. have you checked for current at the bulb sockets?
Fast flash indicates that the flasher does not sense the load of your front signals. Ergo: connection is broken somewhere.
It could be the push-on connectors behind lamp socket inside of the turn signal stalk. Just get a voltmeter, open the turn signal and start chasing down the bad connection. Very simple.
