Anyone out there know how to change the air filter on 1600 GTL ??
Printable View
Yup!
Remove Tupperware and its right behind the gas tank. I can't remember 100% wo looking at my service manual but I think you can do it by removing just the Tupperware covering the tank. The tricky bit (for me) was getting the two panels on either side of the filler neck off - they slide back and you tilt the rear up once you have all the torx screws out.
Thanks will give that a try.:thumb
Good write up on how to do it at k1600forum.com fwiw
