Anyone have lead(s) on a trailer hitch for the 2013 K1600GLT and associated wiring that protects the CANBUS?
Printable View
I would check with Bushtec. They have the wiring figured out from earlier canbus models and may have a hitch , at least in the design stage.
Bushtec definitely does have a K16 hitch -- recently released (in the last month or two). The different versions may be found here: [url]http://www.bushtec.com/BMW-Motorcycle-Hitches-from-Bushtec-s/21.htm[/url]
Thanks! I will give Bushtec a shot.
[QUOTE=91466;833059]Thanks! I will give Bushtec a shot.[/QUOTE]
If you decide to install it yourself be sure to let me know (here or PM). I will save you a lot of time and headache. -Roy
I bought mine at DMC sidecars complete witch wire
I picked up another GTL in January, and installed a Bushtec in place of the DMC hitch I had on my previous K16. For the electrical, you can also get an isolator from Bushtec, or just purchase an isolator directly from Electrical Connection.
