Link to ad
[url]http://sfbay.craigslist.org/sfc/mcy/3307948525.html[/url]
David Sword
Printable View
Link to ad
David Sword
Sorry, just dawned on me that the forks are different. I'm a newbie.
David Sword
Cs use the same tubes and sliders as the early (pre-Showa fork [pre-8/91]) Ss, but some of the internals (springs, dampers, pre-load spacers) are different.
Your springs will be junk, so if you used the C tubes, you would still have to buy springs and use your dampers. So basically all you are using from the C is the upper tubes and you would need to rebuild your internals (not that expensive if you can do it yourself). I would recommend a nice set of Progressive Suspension front springs (about $90).
I believe that 2valve K100RS (Sport) forks after '85 are the same as K75S forks, but I'm not POSITIVE at the moment. The only difference is the upper triple clamp. Springs and dampening appear identical.
:dance:dance:dance
[QUOTE=98lee;826584]Cs use the same tubes and sliders as the early (pre-Showa fork [pre-8/91]) Ss, but some of the internals (springs, dampers, pre-load spacers) are different.
:dance:dance:dance[/QUOTE]
Back home!
I've stripped it all down, and the left and right fairing panels look like they *might* be repairable, but I'd really like to start with some nice straight pieces. Front centre panel - same. The inner piece is cracked and will have to be replaced..
Thanks for that great information on the forks. I have sourced a set of used forks from Quebec from a bike that was in a rear end collision. They've arrived already and look good.
Good news is that it was an S, so the springs will be appropriate (hadn't thought of that). I'll need to get some fork seals, and a new headset bearing and rebuild it all.
My old bearings were notched and I was going to rebuild the head over the winter so I would have been taking this all apart anyway. No harm no foul.
Bad news is that the fairings on that crashed bike are already sold...and it was even marakesh red !:banghead
For those of you who have offered part by PM - I will be in touch again soon as I figure out exactly what I need. I took it apart in the few spare moments I have so I haven't even really done the close inspection yet.
I'll try to get some photos up. It's getting dark sooner so that makes it a bit more tricky.
PS - I've been dreaming of doing a cafe/bobber conversion. Trying to figure out if that would be more or less work/$ than putting it back to stock. I would lose the utility of the saddle bags and windshield, but gain the cool points. A photo is attached of a rattier version f what I'd be going for.
I know this sort of thing isn't popular on this board - but that's one of the reasons I'm posting here - so you can talk me out of it!
Truth is I'd be in the market for another 75S pretty quick - they're just such damned good all-rounders.
[QUOTE=jwetering;829498]
.[/QUOTE]
And they are from an S that was built BEFORE 8/91, correct?
:dance:dance:dance
[QUOTE=98lee;830067]And they are from an S that was built BEFORE 8/91, correct?
Yes sir - a 1989 K75S. (phew)
What's the difference for those who might read this thread later Lee?
The post 8/91 bikes used Showa front forks. They are a different diameter and had different internals and different sliders (they look a little different around the axle clamp). The most visual difference is they do not use the big rubber dust boot over the fork seal.
:dance:dance:dance
[QUOTE=98lee;830155]The post 8/91 bikes used Showa front forks. They are a different diameter and had different internals and different sliders (they look a little different around the axle clamp). The most visual difference is they do not use the big rubber dust boot over the fork seal.[/QUOTE]
Hey, 98Lee,
Any advantage of the early forks over the Showa or the other way around?
Not in my opinion. Others may have a differing opinion. Either way the difference is not much.
:dance:dance:dance
You save money on brake fluid ;)
