Missing Spacer on Front Axle- 88 k100
OK its been awhile since I did anything stupid and talked about it on a forum. I replaced my front tire for the first time back in January. Since then I have been losing air in the front slowly and I finally decided to look into it. My new metal air stem seem to be bleeding air so I replaced it.
Problem is that when I went to put my wheel back on, my small spacer was missing. I clearly remember pulling the axle out cleanly, the big spacer dropping and me placing the axle in a work tray. So either I forgot to replace in in January or it came without a small spacer. Can the brake rotors hold the wheel in place? Would it have damaged my bearings?
I think it is #5 on the chart.
[IMG][IMG]http://i1089.photobucket.com/albums/i342/jpevehouse/bush_zpsb30f0836.jpg[/IMG][/IMG]
