Aluminum spray cleaner Eagle One
Since the topic has come up before, both in ON and airhead news - here is a product that is acid based which cleans aluminum very well. Degrease the aluminum before use.
[url]http://www.eagleone.com/mag-wheel-cleaner#[/url]
Autozone sells this, and also includes the MSDS:
[url]http://www.autozone.com/autozone/accessories/Eagle-One-23-oz-etching-mag-wheel-cleaner/_/N-255s?itemIdentifier=286633[/url]
This is the real deal and will clean aluminum wheels, and/or the aluminum hubs, forks, and engine. However, it is nasty stuff. Heed the warnings and follow the directions carefully.
The primary ingredient is phosphoric acid and a secondary ingredient is hydrofluoric acid, which is extremely hazardous (i.e. it will hurt you). Wear gloves, glasses, use outdoors upwind of the spray, and have a garden hose at the ready when using this product. If you get it on you, rinse immediately with the hose. It does a really good job and requires almost no effort to bring old aluminum back to like new, but must be used carefully.
