"Tried" to install an LED strip for brake/running lights... Had used same type strip/wiring harness on '09 K1300GT. I found the wire for brake lights, and strip works fine, but, when I connect to running light, breaker pops... Any idea? Do I need something?
Also, where can I get a Can-bus connector to plug in to horn wiring harness? Want to install aftermarket horn and need a can-bus to spade connector to plug in in to 12v relay. Plan on using 4 connector relay....
