r90 Rear Brake Light - Always on
My brake light indicator came on when I was riding home last night, checked the brake light and it is constantly on - as though I'm always braking.
I did a little searching to see what was wrong, I pulled the lead off of the brake light switch on the main cylinder - the rear brake light is still on. :banghead
What should I do to trouble shoot this further?
1 Attachment(s)
Running Light on the Brake Light
My tail light is still intermittent, usually in the not working position. I have a brake light, but no running light. I've replaced the brake light switch, on the master cylinder, with a new one. I have a multimeter, which I'm just learning how to use, when I read the green/brown wire and a ground wire I get reading of 3.3 - should this be 12? the bulb contact read 3.3 too. What else should I try?
[ATTACH]36371[/ATTACH]
