I've been (unsuccessfully) searching for products that you would use on a CANbus system to connect the sidecar lights to the bike. I have an '05 R1200ST.
Thanks,
phil
Printable View
Thanks,
phil
I'm by no means an expert on this but I would think you'd want to add a fuse block, e.g. centech, eastern beaver, fuzeblock. You'd get your power this way avoiding the CANBUS system and run a small trigger wire from the headlight plug which wouldn't effect the CANBUS system.. You haven't stated exactly what you want to add?
