Rear Main Oil Seal Removal ~
I believe that folks are making more of a job out of this than is necessary. I had planned to disassemble an engine for some parts and finally got a chance to photograph the technique. Here in photographs is how I remove a rear main oil seal from the engine case of, in this case, a 1978 R100/7. Notice that the bottom lip of the seal is black from oil leaking past it and, the outside edge of the seal is even with the engine case. The seal is an original factory plastic seal correct for 1978 which has probably not been replaced before this.
First photo is the seal in place: Note oil on lip and seal position in case.
So, 'blocking the crank' does NOT go without saying so...
[QUOTE=donbmw;730106]I hope you block the crackshaft before doing this.[/QUOTE]I did not block the crank shaft. The empty engine block and some of the parts are currently sitting in my SK machine. As illustrated there is no prying done to release the seal - its diameter is reduced and it's pulled from the pocket 'almost effortlessly' which was exactly the point of this post. Putting a new seal in or the fly wheel back on is quite another issue especially for anyone doing this job for the first and only time they are likely to need it done. Block the crank shaft as necessary....
Note that sometimes you must peal a bit of the plastic away to get to the metal core of the seal...
