New Nolan n103 on Day Two...
[B]Day one:[/B] Noise, yes. More than Shoei? No. Just different. High speed 70+ noted shaking of helmet. Turn head to either 2pm or 10pm and I feel an air leak on that cheek. Quite comfortable over all. Pinlock fog barrier a must to install. Any breathing creates fogging.
So far happy with it.
[B]
Day Two:[/B] It's raining. Same as above notes except...
It @#$%!* Leaks. It started to weep at 30 mph in a very light rain.
WTF?
By the time I got to work one hour later...
Three separate rivulets running on the inside of the helmet.
No sign of why on the helmet.
Again. Brand New.
Call CIMA if you have a problem with a Nolan
Nolan has a 5 year warranty and they stand behind it. Number in post above. Mine doesn't leak. Look for this before calling. Make sure that you have the visor properly aligned in the rotating mechanism. If you are a cog off, it won't seal right.
