1 Attachment(s)
Bottom Skirt Fitment
Shown is an incorrectly mounted bottom skirt
As you can see the support tang should have been inside the notch to provide support as designed.
Please note that it is possible to be assembled in this manner and the large side plastic will be bolted onto it - this leaves the middle of the bottom skirt flapping in the breeze so to speak.
1 Attachment(s)
Correctly mounted bottom skirt - here you can see the tang inserted correctly - green highlight is showing the hole alignment to the nut is properly in line
1 Attachment(s)
Side Foams
Behind the large side panels are supporting foam.
You can see these pieces when you are on the bike.
When you take off the panel they usually fall off.
They only go on in one positioon - unfortunately I had a little bit of trouble finding the right spot quickly - was a good laugh on me.
Shown below is where the Left Side foam should be placed for assembly.
1 Attachment(s)
The right side foam placement
This completes the general plastic removal for maintenance.
All comments and feedback is welcome - please pm me with them.
